left over parts
brand new kaaz diff oil 2l unopened $70
hpi front pipe needs a spot weld as i had a egt gauge sensor in it $100
De-cat pipe $40
power steering reservoir new not used $80
4.3 diff crown and pinion r200 none abs just taken out of my skyline diff $150
https://www.sau.com.au/forums/topic/466739-left-over-parts/
