  • Replies 112
Yeh i thought to myself, what if i do all this research, bloody calculations, then fork out the dough for the parts and everything, finally get it on my car and its ghey, what a waste of time... and in the end when i tried to save money originally, i think id end up spending more.
At this moment, ive made a list of turbos that would be suitable for me.
HKS 2835 56Trim .73AR, or HKS 2835R PRo (internal wastegate)
Garrett GT30 56Trim
Trust TD06SH-20G.
Ill just have to do more research and find one cheap :( hehe
You can get a new HKS GT2835ProS landed in AUS for ~3k.
The GT2835Pro version is around $100 or so cheaper.
Makes you wonder if it is worth fiddling with an external gate for this application when the ProS version has been known to make 280rwkw on 1.6bar of boost.
This is from Nengun
What turbo core and compressor cover is freebagn using in a vvvvvvl exhaust?
from memory, he's running a GT3040 core with a garrett A/R .60 compressor housing and a sierra cosworth A/R .63 exhaust housing.
Garrett GT30 56Trim
Trust TD06SH-20G.
Ill just have to do more research and find one cheap :) hehe
here's on for ya;
http://www.japanesemotorsport.com.au/partsinstock.htm
Im thinkin of gettin a TD06-19c, mattR had one and made 286rwkw on bp98 and 313rwkw with toulene.....
 Decisions decisions.
Correct me if im wrong, but MattR had the TD06, then sold it and had the HKS T04-R on a manifold with twin external gates, and a Sub Zero plenum which got him up to the 313?Rwkw
Very interesting though....I have noticed (in my short turbo career:D) that no one seems to get 300 rwkw or over with an internal gate?
Anyone care to show me an example otherwise? I know you can get the 3037 Pro S which is rated the same as the 3037s, if not a little more, but has anyone actually seen good results ie 300 + rwkw on an internal gate?
Sorry for the hijack Enrico, though it may help others....including me :)
I'd say the 3037ProS will crack 300rwkw rather easily on the grounds of the 2835ProS pulling 286rwkw.
A t3/4 type back yard turbo will always have problems with boost creep due to the gate being way to small, you can only make the gate so big before you run out of room. The back yard turbo is a trial and error way of doing things, the problem is a lot of turbo shops will say 'yer it will work' yet really you are a guineepig. (Sky30 and his RB30DET)
HKS internal gates on the other hand have been designed with a large flap (45mm from memory)
Trying to find how well the 3037ProS really works is a problem, no one has published their results.
Guess your gunna have to make yourself up a guineapig suit then eh Joel :) I never had any doubt the 3037 ProS wont make it over 300rwkw...just seems too good to be true. Still requires a new manifold for the 3037ProS? If it doesnt (by memory just needed a 10mm spacer plate to clear the block?) then you are up for a new manifold...
The only added cost then is the external gate. Unless you need to spend more on the 3037 ProS to get it to hold boost, ie stiffer springs, or a top of the line boost controller...?
Catch my drift ? :D
300rwkw on the std manifold is pushing it.. :cheers:
EBC's have no issues holding boost, they work hard but do the job.
Every one needs an EBC up at that power level anyhow.
It gets too hard pushing 300rwkw.
I some times think I will settle for 270rwkw.
Slap a turbo like freebaggins on it and be happy with the response and stocker look.
I may have to talk to sky30 to see how happy he really is with the larger laggier turbo over his initial 240rwkw setup.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
