300rwkw daily driver running 22psi on 98 petrol- dyno sheets available
Mature owner for 6 years, never raced or abused, clean car.
Timing belt and water pump changed at 100 000kms
Oil and filters regularly changed every 7000kms
Gearbox and diff oils done
Accident free and no money owing
Need this gone as I need a 4 door
Precision 5858 0.63a/r ball bearing turbo- sharp lowdown response
Turbosmart 38mm wastegate with pipe merged into 3inch dump
3inch custom turbo back exhaust - very mellow & smooth
sounding with the wicked RB scream when needed
PowerFC with commander
Electronic boost controller
Walbro 255 lph fuel pump
750cc injectors
Z32 airflow meter
Large front mount intercooler and piping kit
Boost gauge
Short shift kit
NPC Carbotic heavy duty clutch-only slightly stiffer than stock
Bilstein height adjustable suspension- very nice and firm not harsh like coilovers
18 inch deep dish rims with aggressive fitment
HICAS lock bar
Adjustable camber arms
Front strut brace
265/40/18 Federal 595RSRR semi slicks on the back, these grip n go!
Tuned by JEM and also Unigroup
Nothing left to do, just enjoy!
No swaps and no test pilots thanks.
Please note that price is $22500 ono, come have a look n throw me an offer
  • 11 months later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
