Selling 1987 R31 Ti sedan
hey guys I'm selling my R31 Skyline
It's a 5 speed manual with a near new exedy clutch, not sure the type but the clutch disc has the 5 arms on it, i think its a ceramic type one. the gear box is a standard r31 box
It's the midnight blue metallic colour but being a 30 year old car all that is pretty faded now, the car would suit somebody looking to re spray and modify.
it has the import style afterburner taillights in place of the standard hotplate lights.
the interior is in very good condition for it's age, however it is missing a radio unit
the engine is in good condition, it has high km's, around 420,000 however it starts and runs fine, doesn't blow smoke, and basically doesn't use much oil at all (maybe a 1L between services) its completely standard and never been modified
the car is currently unregistered and I'm looking for a quick sale , given the import tail lights, good quality clutch and the condition of the interior , I'm asking $400 for the car as it is. please don't ask me for individual parts as I'm not wrecking the car , it is a whole car for sale.
the car is located in bacchus marsh , vic
I can put up photos on request
for any more questions about the car please contact me on 0401 942 607
https://www.sau.com.au/forums/topic/467616-selling-1987-r31-ti-sedan/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
