RB20DET GTX2867r E85 Unopened
Hey everyone just wanting to get some thoughts on running a GTX2867r on an RB20DET with all supporting mods and E85. I've read the sticky RB20 turbo upgrade thread and hadn't seen anyone running this turbo on the RB20. Wanting to know if 350rwhp should be achievable on E85 with it being unopened, thanks :)
Power wise it is within what the engine can happily take and what the turbo can easily make.
If the goal is to make only 350whp max I would get the 2863 as it will be plenty enough already and save some late spooling on the 20. The question is how you plan on installing one on your engine ? Most housings are T25 flanged or twinscroll T3 externally gated. Either way you'll need some fabrication/modification needed to make it fit, or find a 6 bolts HKS GT25xx housing.
I'd personally go with a gt3071. They flow very close to the same and it will bolt in not having to try and switch over to t25.
Red- gtx2867r  t25
Blue- gt3071 w/ billet wheel  t3
Edited by Ed.williams5
 Share
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
