You can replace it with one of these, goes from master to slave cylinder http://www.ebay.com.au/itm/HEL-Braided-CLUTCH-Line-kit-NISSAN-Skyline-R32-GTS-T-GTST-Full-Length-/271611272122?hash=item3f3d4b1bba:g:5OwAAOSwnDZUG52L Pm Dose Pipe Sutututu (johnny), he can probably do a better price. The other options are brand new oem from Nissan, wil most likely need to be ordered or second hand oem from a wrecker like skyline spares in Sydney or Osaka imports in Melbourne. Where are you located by the way? As far as bleeding at every joint, it means where the hose screws into the master cylinder, you need to loosen it 1/2 to 1 turn and bleed the master cylinder from there, tighten the fitting fully and move on to the next join and repeat and finally bleed at the nipple. Does that make sense to you? You may be able to get away with just bleeding from the nipple you may not.
Yeah I will definitely get that one in the future problem is I dont have time to wait for delivery as I already bought an unregistered vehicle permit so I only have a limited time to get a RWC. Im located south east melbourne.
Image result for r32 gtst clutch master cylinder
So I bleed the master from the nipple on the right or the fitting under the reservoir?
3 minutes ago, admS15 said:
Bleed both, cant hurt. Try Osaka imports in knox for a used clutch line or find a local hel distributor.
Yeah im gonna take it to a local clutch place and hope they can give me a new line at least for a temporary fix then imma get the RWC and switch everything to braided
19 hours ago, Ed.williams5 said:
Your best bet is go and have stainless line made up.long enough to go from clunch master down to slave then just have to worry about one.
This? : http://www.ebay.com.au/itm/271611272122?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Will this mean I can completely bypass the dampener as well and remove all the metal lines?
Yes
31 minutes ago, KiwiRS4T said:
Yes
Thank god. I the little screw thing that goes in the dampener is leaking now and the nut is completely rounded, was seriously about to just give up
57 minutes ago, KiwiRS4T said:
No you can rip it out
Yeah thanks guys in this thread, i bled the clutch and the brakes as well and now everything running even better than before so THANKS :)
  • Like 1
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
