Power jack in centre console of v36?
Hey guys really stupid question but... How do you connect to the power jack in the centre console? I.e. If I want to charge my phone via usb, is there someway I can plug into this power jack? It looks to be the same size as a cigarette lighter but using that adapter doesn't fit?
https://www.sau.com.au/forums/topic/468233-power-jack-in-centre-console-of-v36/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
