WTB: R32 GT-R 1990 front speaker mounts and power window switch
Hi all,
Fixing up the old GT-R and after a few parts:
Passenger power window switch
25431-01U00 Switch Assy-Power Window,Assist
Driver and Passenger front speaker mounts
28166-01U01 Bracket-Front Speaker,RH
28167-01U01 Bracket-Front Speaker,LH
I would prefer near Melbourne so that I can view before buying but will pay for postage for the right bits.
Please PM or reply here if you have any of the above in good working order.
Cheers
Rob
Both of these were for sale on a GTR Parts facebook page. If I manage to find the post again I'll edit my post with the link.
I do have a passanger power window switch but I am in Sydney. PM me if you are still interested.
Passenger Power Window Switch received thanks
  • Like 1
Still after the following:
Cheers
Rob
  • 3 weeks later...
1 hour ago, GH05T said:
you looking for these?
if so ill see if i still have them in  the shed.
They look different to my GTR ones. Different speaker size too. What are they out of?
  • 4 weeks later...
Driver and Passenger front speaker mounts for an R32
Cheers
Rob
20 hours ago, jmknights93 said:
Rob, I managed to find some speaker mounts for you. You have a personal message waiting from me.
Speaker mounts on their way thanks to @jmknights93
All items in this thread purchased now thanks!
  • Like 1
Glad I could help out.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
