Lads and ladettes,
couple of spare sets of wheels up for sale....
17x9+12 volk gramlight 57D, satin black colour (set): $1200.....new in box
17x9+12 volk gramlight 57D, luminous orange colour (set) $1500 with 235/40 and 255/40 Nitto NT01 semi slicks fitted (old but only a couple track days of use). Few scratches from use and tyre fitting
17x9.5+15, 18x10+25 advan RS, silver colour (set): $2000
17s fitted with 235/40/17 Federal 595 tyres (old but good tread),  18s fitted with 245/40/18 Federal RSR tyres (few years old but never driven on)
Edited by boost_bus180
Mazworx SR20VE P11 inlet manifold: $600 brand new never fitted comes with fuel rail still in packet and other vac fittings. Can include a smaller flange from plazmaman for an extra $30
IMG_20170110_152814.jpgIMG_20170110_152834.jpgIMG_20170110_152307.jpgIMG_20170110_152529.jpg
MAZWORX SR20 -16 water outlet fittings (hot and cold side): $40 (new) IMG_20170110_153228.jpg
APEXI DECS tacho: $300 (new) was fitted and wired up but swapped to a digital dash before it ever got used. Super cool old school discontinued Japness that should have been more popular than it was. cost me nearly $600
Bosch 044 fuel pump (genuine, of course!) bought by mistake. still in original packaging: $140
17x9+37 volk racing emu, black (pair): $200.... no tyres fitted. plenty of marks on them. good skid wheels. 4/5 multi-stud.
17x8+32 volk racing emu, black (single): $100... fitted with a 235/45 potenza tyre. kept as a spare but never needed it. 4/5 stud
TAARKS S13/180sx poly-carbonate door windows: $100... pre-moulded and drilled ready to install for a factory fit. weigh half as much as standard. never fitted.
APEXI gauge controller: $40 (new)
Turbosmart manual boost controller/bleed valve: $15
stock R33 RB25 airbox with snorkel: $100 (no extra charge for the hectic K&N sticker)
POTENZA 'damper for wagon' suspension with wild dog springs to suit C34 series 1 stagea: $200..... unknown kms - was in the car when I bought it. No leaks or knocks. quite stiff. removed cos I wanted to try some nismo ones but they feel very similar.
5 x RB25 coil packs from a series 1 Stagea: $40.... were working fine but kept these as spares after upgrade
RB25 auto radiator from series 1 Stagea: $20.... no leaks or damage. worked fine but upgraded. Good to have as a spare for our bullshit-hot summers
RB25 radiator fan: $20.... no damage
HKS super sucky sucky long time air filter with AFM adapter: $20
BLITZ cannon exhaust stainless silencer: $20.... knocks a few louds off your exhaust note so you can sneak home without pissing off the neighbors
Space saver with new tyre: $10..... sweet paint job and even better offset. will make your RB20DE auto single-peg like a champ.... and also get you out of trouble if you get a flat.
RB25 coil pack valley cover: $20 in excellent original condition
SR20 S13 carbon fiber coil pack valley cover: $50
This Volks, the 9" wide ones, can you show me those in more detail. I wanna see if the colour matchs mine as it might save me painting this purple set I bought to get the 9s
Is it the same colour as this?
A charcoal type black rather than a really dark black?
Hi mate, can u get back to me on 0432 446 550 I want to put cash in your acc for a bunch of parts so I don't miss them can wait till u get back to send them or I'll pick them up but really want to put the cash in to secure them, again please text me on the phone number provided,
cheers,
Sean....
  • 3 weeks later...
  • 1 month later...
Parts still available include the following:
17x9+12 volk gramlight 57D, luminous orange colour (set): $1200
17x9.5+15, 18x10+25 advan RSII, silver colour (set): $2000
17x8+32 volk emu, black colour (single): $100
space saver 5 stud: $10
180SX tinted rear hatch glass: $20
NISSAN S15 engine mounts SR20: $100 (new)
BLITZ exhaust silencer: $20
Turbosmart manual boost controller: $15
Front seats to suit Series 1 C34 Stagea: $20/pair
POTENZA shocks with Sheep Dog springs Series 1 C34 Stagea suspension: $200
RB25 air box: $40
RB25 air box with snorkel: $100
RB25 auto radiator from Series 1 C34 Stagea: $20
RB25 coil packs (5) to suit Series 1 C34 Stagea: $40
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
