Hello,
I recently purchased an s15 (sr20det) that sounds like a tractor, the owner assured me that it was due to solid lifters he installed with the last rebuild. However after a wee cam inspection I suspect that his engine builder installed camtech hydraulic cams (the lobes are very broad). Has anyone got any experience with this situation? Any idea what effect it will have on the power curve or if I'm likely to break anything?
Cheers
Edited by lsmith
Believe it or not it's the camshaft sprocket. Vvti. Vtech. From what I know SR20 has no solid lifter. The have a lifter retainer that keeps them from jumping out. I have no idea how you would run a solid lifter on a SR20 as the lifter isn't under the cam. It's offset and uses a rocker arm to press the valves open. Lifter retainer are made out of stainless steel iirc. And keeps them in place at high rpms. I would replace both vtech cam sprockets as there notorious for valve train noise. Sound like tractor. Providing oil pressure is good and solenoid are good and all electrics to solenoid is ok.
Hmmm probably should been more clear, this isn't a stock sr20det. The engine has been built (forged pistons, manley rods, rockers stoppers, head studs, etc) and has a solid lifter conversion.... which in this case just means solid pivots, guides and shims. e.g. http://www.tomeiusa.com/_2003web-catalogue/e098_pivot2.html
The VVT has been removed and adjustable cam sprockets added.
EDIT: From what I've read there are different cams profiles for solid (mine) vs hydraulic pivots (standard), so I'm wondering what effect mismatched cams would have...
Edited by lsmith
Ok that's better. If it has solid lifters then. The clear is critical. Sounds to be like it's all mest up clearance wise. I can remember a mate of mine doing a video of how he does the clearance. I'll see if I can add a link in here
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
