Merchandise
I was wondering if we could possibly get some merch designs up on a hosting site like Redbubble (http://www.redbubble.com/).
As I understand (I could be wrong) basically all SAU has to do is put the designs up, then anyone and everyone can buy whatever merch they want and everytime there is a sale you guys get a small cut.
Just something to think about as I recently bought a minitruckin' t-shirt from an American forum I frequent that didn't ship to Aus, not to mention I've bought stuff off them multiple times and it's always been good.
Just a thought :)
https://www.sau.com.au/forums/topic/469079-merchandise/
SAU logo is a good start. if someone has the state logos that'd be cool too, I've lost my SAUWA hoodies.
Start from there I suppose? If we did logos we could get stuff like long sleeve t's/jumpers made for Motorsport.
Perhaps if people were particularly good at graphic design they could send some pics through to you guys for uploading?
https://www.sau.com.au/forums/topic/469079-merchandise/#findComment-7811487
14 minutes ago, Gts-t said:
Id be keen on some merchandise as long as the quality is very good
I've purchased several t-shirts and a cushion cover from Redbubble, no complaints yet.
  • Like 1
https://www.sau.com.au/forums/topic/469079-merchandise/#findComment-7811517
  • 1 month later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
