Nissan R34 GTR V-spec rolling shell
Hi SAU members and non members I have decided to sell my project R34 GTR on here is just a little information about it, I purchased it a couple years ago off a friend I was planning to finish it off but other things has just came up, it has no compliance but it can from import monster was told once everything was completed take it to import monster and he will take care of it,
So it's a 1999 vspec white comes with complete interior no engine or box missing some of the engine loom front bar is yellow has r33 gtr breaks, there is a bit of information so it's best to just call me on 0466589457 to discuss further
asking $25,000  car is located in sunshine, Melbourne
I'll post up pics soon or contact me and I'll try to send through mms,
https://www.sau.com.au/forums/topic/469120-nissan-r34-gtr-v-spec-rolling-shell/
Just to be clear, it was a few years ago that I looked into being able to arrange compliance. With the rules shifting and sentiments from Dept of infrastructure changing, I can not be sure that it's still possible at this point so anyone looking to buy should take this into account.
  • Like 3
Thanks for clearing that up import monster, I know it was a few years ago when my friend contacted you about this car but I was told doesn't matter how long you could possibly get compliance but as you said rules may or will be changing, I just hope if this car does sell I hope you could help out the new owner about getting compliance,
Also my apologies if I named your company into my ad, it was just to make the buyers aware of the situation.
Just for everyone that has contacted me requesting pics of the car I'll be posting pics on Monday as the car is at the workshop but here is pics of the car before I purchased it, please note the pic is shown with a z tune kit it does not come with it just standard gtr kit that will be on,
