Nissan R34 GTR V-spec rolling shell
Hi SAU members and non members I have decided to sell my project R34 GTR on here is just a little information about it, I purchased it a couple years ago off a friend I was planning to finish it off but other things has just came up, it has no compliance but it can from import monster was told once everything was completed take it to import monster and he will take care of it,
So it's a 1999 vspec white comes with complete interior no engine or box missing some of the engine loom front bar is yellow has r33 gtr breaks, there is a bit of information so it's best to just call me on 0466589457 to discuss further
asking $25,000  car is located in sunshine, Melbourne
I'll post up pics soon or contact me and I'll try to send through mms,
https://www.sau.com.au/forums/topic/469120-nissan-r34-gtr-v-spec-rolling-shell/
Just to be clear, it was a few years ago that I looked into being able to arrange compliance. With the rules shifting and sentiments from Dept of infrastructure changing, I can not be sure that it's still possible at this point so anyone looking to buy should take this into account.
  • Like 3
Thanks for clearing that up import monster, I know it was a few years ago when my friend contacted you about this car but I was told doesn't matter how long you could possibly get compliance but as you said rules may or will be changing, I just hope if this car does sell I hope you could help out the new owner about getting compliance,
Also my apologies if I named your company into my ad, it was just to make the buyers aware of the situation.
Just for everyone that has contacted me requesting pics of the car I'll be posting pics on Monday as the car is at the workshop but here is pics of the car before I purchased it, please note the pic is shown with a z tune kit it does not come with it just standard gtr kit that will be on,
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
