FS - 1995 R33 GTR Vspec
Hi,
Up for sale is a 1995 R33 GTR VSpec with 122xxx KMs.
It is a little rough around the edges.  And, full disclosure - It has some history.  I'm keeping it out of the post but will happily reply to PMs.
Recently registered and expires 25/10/2017.  All fluids changed just before re-registering.  It's due for an oil change - six months is nearly up.  Started weekly, maybe driven every second or third week for 100 - 200 KMs.  Red Line Lightweight Shockproof in the gearbox, all other oils/fluids per specification.
  • It had a misfire.  This is now long gone - see my posts about this.  Fixing this, the ignitor pack and plugs have been replaced/changed.  Issue was with the coil packs.  Another set was bought, cleaned up and dielectric grease sealing them.
  • It has a leaking injector.  Second hand set purchased along with a rebuild kit.  Injectors replaced with new o-rings etc - no more leaking injector.
  • Bridgestone Potenza RE003s fitted mid December 2016.
  • Mongoose M80S alarm installed.  No bells and whistles, just arm/disarm with an impact sensor.
  • All round wheel alignment done October 2016.
  • New battery
  • New radiator and top hose (bottom hose was A-OK)
This car was my daily for a long time, then became a weekend car.  Oil changed every 5000 KMs, or six months with maintenance and problems done by myself or a mechanic.  I had plans for the car and like many others lost interest and just enjoy driving it as is.  Mechanically it is in great condition and drives well.
It is a little rough around the edges.  Scratches, dints and gutter rash sum it all.  It isn't a show car.  Odometer recently stopped working (it occasionally ticks over) with high 121xxx KMs when it stopped, it is now 122xxx.  Haven't gotten around to fixing it.  I started to collect parts to swap them out, but only collected and swapped nothing - this be your job.
No major modifications.  Exhaust and dyno at 245KW - old school Racepace days.
Buy the car and get:
  • Spare injectors
  • Spare ignitor pack
  • PowerFC with hand controller
  • Nismo AFMs
  • A collection of front/rear floor mats
  • Spare coil packs
  • Parts of a Series 1 steering wheel - the car is fitted with a Series 3 wheel
  • What I think is a complete boot set of carpets
  • Left and right hand door cards
  • Replacement passenger side tail light.  A drivers' side (or two?) tail light.
  • Whatever else I find that belongs to it
Conditions vary of the listed parts.  All included with the sale, will not separate.
I'll say it comes with a RWC.  I expect no issues and will start the ball rolling only with a serious buyer.  Price $32,000 ono located in Altona.  I'll happily drive you during an inspection and there will be no test pilots.
VIN - 6U900BCNR33001030.
And no, I didn't wash (vacuum or dust) the car before taking pictures - WYSIWYG.  It was raining all day today and I ran the gauntlet.
PM me if interested.
https://www.sau.com.au/forums/topic/469142-fs-1995-r33-gtr-vspec/
  • 1 month later...
  • 1 month later...
It looks like a clean car. Maybe give it a wash, touch up the wheels and front lip and post some more photos that will present the car a bit nicer than it already is.
Good luck with the sale.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
