Out of Japan both are hard riding and not really suitable for the aussie goat tracks we call roads - but all coil overs will do this to some degree anyway.  Both have good names as far as reliability and the like, but if you have them on your car you won't have any discs in your back within 3 months - they are that hard.  There are aussie built [in Tein anyway] ones that are supposed to be better for us, but u would be paying top $$$ for a set.
I have Bilsteins btw....I did what Nizmo suggested, saved and bought.  Not recommending them, just stating a fact, there are others that are just as good or maybe better.
https://www.sau.com.au/forums/topic/469162-hks-or-tein/#findComment-7812797
Check out cusco, bilstein, KW and other stuff.
Had non-adjustable bilstein shocks and tein springs on my GT-t - great setup by a really awesome alignment shop.
Went from tein luxury sport (crap) to ohlins road and track on my r - ohlins noticeably superior but much much harder :)
  • Like 1
https://www.sau.com.au/forums/topic/469162-hks-or-tein/#findComment-7814756
I bought a second hand Tien kit from someone i trust, then got longer, softer springs for the front to tweak my setup. I'm happy with it, but if I were to do it again would probably go MCA, even though there spring rate selection is unconventional.
https://www.sau.com.au/forums/topic/469162-hks-or-tein/#findComment-7815176
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
