FS: 1990 R32 GTST with RB25DET conversion
Price: $16,000 ONO.
Rego: Till Feb 18
Contact: Leong 0401526517
https://www.carsales.com.au/…/Nissan-Skyline…/SSE-AD-4570892
For sales is my 1990 R32 GTST Skyline with RB25DET conversion.
I have owned this car for the last 10 years and took it off the road about 5 years ago when I bought a daily driver.
An R33 S2 wreck was purchased, with all the good bits being reconditioned and transplanted into the R32.
My original vision was to build a fun, fast weekend/track car to play with.  A bigger motor in a lighter car with gearbox and diff to match, bigger brakes to deal with the increased horse power, tomei poncams, Greddy front facing plenum, intercooler, new heavy duty clutch plus all the supporting mods required to build a really fast, really fun car to drive.  Quality parts were sourced and no expenses were spared.
Aesthetically, it is in good condition for its age.  It has a couple of minor imperfections, stone chips etc.  The biggest of which is a small dent in the passenger rear panel.  I have recently detailed the car and cleaned it from head to toe.
The platform has been created, however I am no longer in a position to complete the project.
All it needs is a tune and it will be an awesome, fun and fast car. Good to drive daily, a weekend warrior or even kept as a classic car.
However, with a bigger turbo and some injectors you are looking at an extremely fun car that will also be really powerful to boot.
The choice is yours.  All supporting modifications have been done; the question is really how far you want to take it.
This car has been kept registered, and will come with rego.
131xxxkm on the clock
Mods include –
R32 GTR bonnet
R32 GTR front Grille
Rb25det s2
Rb25det gear box
R33 s2 diff
R33 s2 AFM
R33 s2 front and rear brakes
Rb25det s2 turbo
12psi actuator
HKS EVC boost controller with custom mount
Gtr fuel pump
New Project mu pads front and rear
New RDA brake discs front and rear
Greddy aluminium radiator and cap
Tomei 256 pon cams
Plazmaman swept back Intercooler - 600x300x76mm
Custom Intercooler piping
Custom intake
HKS panel air filter
Custom Catch can
14 row oil cooler
Decked head and block
Cleaned head
ARP head studs
New valve stem seals
New head gasket
New waterpump/idler & tensioner
New timing belt
New alternator belt
New power steering belt
Hicas rear lock bar
Battery relocation
Fuse box relocation
Nismo dash (rare)
Tien coil overs
Cd/mp3 head unit
Bride door trimming
Exedy HD button clutch
Exedy Lightened flywheel
Modified tailshaft
 Car is of eligible age for club rego.
Edited by lteh
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
