M35 VQ25DET rocker cover leak
Hey guys, got an interesting one here. Popped the bonnet the other day as something didn't sound right, could hear a hissing sound like a boost or vacuum leak. Pulled the compressor out and did a boost leak test. Couldn't pinpoint the spot until I put a small hose line into my ear and fished around, turns out the air leak was coming from below a coil pack. Obviously it is coming from the rocker cover seal, the funny thing is that there is no oil passing through, just air, spark plug well was dry as a bone.
Has anyone experienced this before?
Would this be considered a boost or vacuum leak?
Im wondering if in fact it is a shagged seal or maybe the pcv has shit itself and is causing this. As most of us know the seals are non serviceable and new rocker covers are around $300 each. I managed to find a passenger side for 180 brand new but it is the drivers side I require and cheapest I cold find was $318 delivered. I have simply put some 3 bond onto the coil pack seal to try and temporarily seal it up, haven't started it yet, letting it properly cure.
Has anyone successfully changed seals of an existing rocker cover. You tube methods look uninspiring, lol.
Thoughts and experiences please.
https://www.sau.com.au/forums/topic/469211-m35-vq25det-rocker-cover-leak/
Nissan quoted me 355. Anyhow, just pulled the rocker cover off and it looks fine, the seals are all intact and in good nick. I'll post pics when I've cleaned it up. Also checked pcv, seems to operate as intended as a one way valve. I'm at a loss to explain why this is happening. Anyone have any other ideas?
I think I've figured out whats happening. I noticed the bolt securing the coil pack that was leaking was longer than the others. It had penetrated through the cover. I think the air was getting between the threads and leaking out. When I was spraying soapy water it was bubbling at the bolt area. I have put some silicon in the hole now and on the threads of a correctly sized bolt. Will see tomorrow afternoon when I start her up if I am correct. I did also fill the seal up with silicon before I worked out what was happening with the cp bolt. Pictured below.
Yep, luckily the plastic was still hanging on for its life and didn't fall into the valve train. I saw it while I was cleaning the cover and flicked it off but I didn't click till I was putting it all back together. Old mate I bought this car off had ultra tune do a service and plug change a few months before I bought it. Probably happened then or possibly in japland. Who knows. Hopefully this is what was causing the tiny leak. Will find out tomorrow.
Leak still persists. Im not going to worry about it for now as there is no oil leaking into the spark plug chamber. The car drives perfectly fine and when i did a boost leak test it was taking a long time for the boost to bleed out of the system. I have ordered a new pcv valve in a last ditch effort before i ignore this. Im not totally convinced that it's the rocker cover seal and don't want to buy a new cover and find i still have the same issue. Im wondering if there is something else going on in the background that im missing, is that pressure meant to be inside the engine? Im sure that time will tell all, till then i'll just keep driving.
I've got a bit of oil on my spark plug on cyl 6 (passenger side), do you have a link to that rocker cover for $180? I've replaced the rocker cover gasket already, which stopped oil weep onto the turbo.
Super strange with that long bolt piercing through...
I'm not at a pc right now but the rocker cover was from amayama uae. Is the vq30det the same though? Shouldn't be hard to find with the part number.
Some bright spark obviously drove that bolt through but it wasn't the source of the air leak in the end. The air is now weeping through the seal around the plug but strangely no oil.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
