rb25det neo(from stagea) with r34 gtt ecu
hey guys i wonder if someone can help me out, i have few wiring problems a can solve myself.
- original car skyline r34 sedan rb20de neo
- swap rb25det neo ( aparrently neo from a stagea since it had 4wd oil sum, and does not have the traction control on the engine) I KEEP THE ORIGINAL LOOM FROM RB20DE NEO.
- first engine is working with r34 gtt ecu.
- engine works fine without the TCM/ABS module ( on r34) disconected but no speedometer
- engine cuts at 4000k when disconeccting the TCM/ABS module.
- i got and stagea ecu to solve the problem (stagea NO ABS or TC), engine pass 4000k normal, i connected the module TCM/ABS and now speedo works and all good, no cuts or etc,
problem i remove the ingnition key and the engine doesnt shut off whith stagea ecu, how can i solve this? please help
PS - my stagea ecu is 23710 0V300 and the first one is from a r34 gtt.
just for the record, my engine also cuts badly at 1 k or 2 k when i plug the ac dryer (3 cables) with either ecu.
Its not the right ECU. The number you quote is for a S1 Stagea with the R33 engine. The Neo engine runs a Jecs ECU. The plug is different. You need to use the 34GTT ecu. BTW all Stageas have ABS. There is a fix on this site for if you have a warning light for the lack of Traction Control.
Hey guys, so is it possible to put an rb25det neo out of a series 2 stagea into a r34 gt (non turbo)?
a) ill be using an r34gtt manual gearbox and a r34gtt ecu
b) Do the engine mounts line up the same?
c) can i use my r34 gt hicas power steering pump on a non hicas stagea engine?
d) can someone link the fix for the traction control fix?
Edited by Jet_Mapex
Yes
ok
dunno - probably big question is is it an awd or 2wd stagea
if it doesn't bolt straight up you should be able to adapt it
May be here:
http://www.skylinesaustralia.com/forums/topic/175032-power-fc-in-a-25t-rs-four-s/page__view__findpost__p__3208663
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
