GDZ-14R Posted April 15, 2017 Share Posted April 15, 2017 Splitfire Coils, R34 GTR Carbon Fibre Cooling Panel, and other stuff R34 GTR, Series 2 RB25DET, and Neo Splitfire coilpacks with mounting brackets. Done between 10-12,000kms. Perfect condition, but upgrading to massive setup. $350 delivered anywhere. Located in Sydney. R34 GTR carbon fibre cooling panel in good condition. Made from high quality resin, Toray (Japan) Carbon fibre, reinforced with fibreglass and finished in a UV protective clear coat. Quick and easy to install. $170. Stock AFM's - $100Stock intercooler and intake pipework - $80Stock Twin Turbo Pipe - $80Stock Cam Gears - $20Stock Cams - $100Stock Front Pipes - $30Stock washer bottle - $30Stock Fuel Rail - $50Samco blue silicone radiator hose, top one used - $30Precision or non-bb turbo oil drain fitting, new - $25Braided black nylon -10 hose, 2.5mtrs, new - $50 Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/ Share on other sites More sharing options...
renchamp Posted April 16, 2017 Share Posted April 16, 2017 i will grab the carbon fibre panel Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/#findComment-7824134 Share on other sites More sharing options...
GDZ-14R Posted April 20, 2017 Author Share Posted April 20, 2017 Sorry it sold pretty quickly. Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/#findComment-7824956 Share on other sites More sharing options...
GC 99 Posted July 8, 2017 Share Posted July 8, 2017 Hi do you still have the intercooler Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/#findComment-7839109 Share on other sites More sharing options...
GDZ-14R Posted July 9, 2017 Author Share Posted July 9, 2017 UPDATE Splitfire Coils, R34 GTR Carbon Fibre Cooling Panel, and other stuff R34 GTR, Series 2 RB25DET, and Neo Splitfire coilpacks with mounting brackets. Done between 10-12,000kms. Perfect condition, but upgrading to massive setup. $350 delivered anywhere. Located in Sydney. R34 GTR carbon fibre cooling panel in good condition. Made from high quality resin, Toray (Japan) Carbon fibre, reinforced with fibreglass and finished in a UV protective clear coat. Quick and easy to install. $150. R33/R34 GTR Custom Catch Can, powder coated wrinkle black, internally baffled, 3x -12 fittings, drain tap, requires some modifying of the fusebox bracket, and some urethane to seal the washer bottle motors - $250 Stock AFM's - $100Stock intercooler and intake pipework (just pipework for both, NOT the intercooler) - $80Stock Twin Turbo Pipe - $80Stock Cam Gears - $20Stock Cams - $100Stock Front Pipes - $30Stock washer bottle - $30Stock Fuel Rail - $50Samco blue silicone radiator hose, top one used - SOLDPrecision or non-bb turbo oil drain fitting, new - $25Braided black nylon -10 hose, 2.5mtrs, new - $50 Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/#findComment-7839261 Share on other sites More sharing options...
dee242 Posted July 9, 2017 Share Posted July 9, 2017 U got a cas? Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/#findComment-7839295 Share on other sites More sharing options...
GDZ-14R Posted July 10, 2017 Author Share Posted July 10, 2017 No CAS. Link to comment https://www.sau.com.au/forums/topic/470024-splitfire-coils-r34-gtr-carbon-fibre-cooling-panel-and-other-stuff/#findComment-7839313 Share on other sites More sharing options...
