Hi all. I have a 1993 S1 R33gts-t, auto, kinugwa turbo, 350gt wheels, low K S2 engine recently had timing belt replaced and plugs, yellow jacket coils. Seats f&r perfect condition, Has been my project car but i dont have time or passion anymore, will part out if not sold in few weeks $3500 FIRM
https://www.sau.com.au/forums/topic/470060-r33gts-t-project/
