Hi ppl,
After my research, I've decided to go the whole hog all at once. Reason: Seems to me that if certain mods are staged, this affects the next mod, then the next mod, etc - also could affect performance, reliability etc.
For Example:
If you just do boost (too high), then you risk reliability so you should do FMIC at the same time. If you do turbo but not injectors, you risk leaning out. If you want a new plenum, you have to think of design considerations for the FMIC. Of course ECU is a gimme cause you once you do boost & FMIC, you need to control iginition and fuel better. Then you need a new fuel system to keep the juice flowing.
I've been told to expect maybe 450 HP ?? Any comments on this ??
Anyway, should be a weapon when it's done. I'll tell you when It's finished - It'll be about a month .
Cheers,
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/
  • Replies 97
Guest Nismo_Freak
Sounds good to me... I would suggest a Greddy Profec B boost controller, cheap and effective. You definately will need a metal headgasket for anything over 400hp, unless you wanna replace the stock one 10 times a week. Heres what I would put on the vehicle, just being more specific and adding a few:
- EGT Gauge
- A/F Gauge
- Boost Gauge
- Metal Headgasket
- Head Deburring/Semi-Polish
- Port Match the Manifolds
- HKS SSQV or Blitz SS BOV
- Wider Rear Tires :burnout:
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-73356
Originally posted by Amir
Sounds excellent. Wish I was still in Queenscliff.
What would 400-450hp pull 0-100 and 1/4mile?
What is daily driving like? Is the car well controlled or all over the place at this power level?
Don't know that answers to these - but will let you know when it's all done.
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-73507
Originally posted by croat
As meggalka said a new head gasket would be a good start... maybe a set of forged pistons -decompressed if u intend to run high boost... what boost u intending to run?
Hmmm, good point re: metal head gasket.!
Re Boost:I think we talked about 10-12 maybe upto 14 to keep the reliability there. I'll do what Megs suggested and get the expected/target figures up front, before the work comences.
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-73509
I know where you are coming from - however, the shop I am taking it to knows EMS back to front and inside out - And I am not going to f*&k with it, so I'm going with the flow in this case. Plus, the new EMS range are pretty good I hear.
Oh, and I enjoy supporting Australian Businesses.
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-73558
Well i've just had a Racing Gear 2400 pressure plate put in and it feels awesome... Unfortunately i haven't taken it for a drive coz i'm getting heaps of mods done too, but the clutch feels really smooth and nice... Compared to a similar clutch which was in another skyline which felt awful... My new one feels similar to the standard one, but a little bit heavier where as this other clutch was heavy and stiff all the way through...
Or if you want a serious clutch go for a OS Giken twin-plate... I heard they rule!!!
Alan.
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-75345
brendan...
Good to see another R33 being given the full treatment :uh-huh:
One thing though... A custom plenum you're planning on getting... I don't really like that idea...
SubZero have done a bit of flow testing on their plenum, so that's quite alright, but if you're planning on getting your mechanics to knock one up, it'll be questionable...
Getting even flow to each individual cylinder is an art, and takes a TON of R&D... I can guarantee you that you will have *very* distorted flow seperation figures from a custom plenum, unless they make up a dozen designs in R&D...
I'd suggest the SubZero or GReddy plenum for your car with those mods.
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-75612
Guest MFX_R33
Hey Brendanf,
Sounds like you have a good package coming. I did pretty much the same thing. I only had a high flowed turbo and bleed then I did a bunch of mods at once. I got FMIC, Plenum, XF throttle body, and EMS all at once. I have run as high as 17psi (getting a bit high for my head gasket) and done 205rwkw. As far as boost control goes, the EMS has a built in EBC, you just need a solonoid to hook up to it.
Who is doing the work for you?
Jeff.
https://www.sau.com.au/forums/topic/4706-im-doing-the-lot/#findComment-75824
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
