  • Replies 97
I really can't say - nothing to compare it to other than the stock ECU - It just sits there and works - (no hand controller).
The car idles, no flat spots, seems easy to tune (I don't touch it though cause I have NFI)
I don't know too many other people using the Stinger on their Skylines - JulianGST from these forums does and he is happy -
One thing I did notice with both our cars (saw this happen to Julian at EC), is that when you dump it - lots of black smoke from the exhaust. I understand this indicates richness, which is a good thing, but the cars behind me may not appreciate it...... he he
I might think about changing the EMS after the engine rebuild, but I want to speak to a few more people & do a bit more research first,
have you got a blow off valve that vents to the atmosphere? cos if you are still running airflow meters then you'll get a plume of black smoke on gear changes as you get a rich injection of fuel as it delivers fuel based on the air the AFM has measured and half of it has been released through the bov. Another reason could be that the air/fuel ratio's get richer as you go up the rev range... a good tune to even it all out will fix that.
yeah, thought about that Joel and is a good option - but for some strange reason - I feel compelled to keep the original engine number ?? Dunno why maybe cause i don't want to go through blue slip process again (after the one it went though at time of import) - I will think about this some more though....
Can you link to the RB30E guide you mentioned ??
Cheers,
GiJOr33,
The EMS doesn't use AFM - THe BOV used to vent to atmosphere, but I got it change to plumback now cause I hated the noise (drew too much attention) and I wanted it be legal.
INASNT,
They are stock injectors high flowed to 610cc - I understand that the flow tests were documented, but I never saw the paperwork - So that's why I wanna get them tested again - to be sure, to be sure.
Also I have heard good and bad things about High Flowing injectors (retrespective to my mods being done) - If I get the results back and the flow and spray pattern (don't know if they can test this) are OK, I will re-use them - If not, I'll be up for new injectors & prolly rail with the rebuild. I'm hoping they will be OK. If not, then It may be one explanation for my little problem.
I wanna get it 200% right
Cheers,
Guest MFX_R33
I have an EMS (not the stinger though) in my skyline and it runs well. I have only had a few problems with it stalling on back off with the aircon on, but that is cause it doesn't currently have a separate tune for the a/c. It is also a bit to do with my large throttle body.
Jeff.
Originally posted by INASNT
B Man
i am most probably getting sard 500cc side feeds for mine. They are around $125 each from greenline at the moment. How much did the high flowing cost u?
Not sure about cost as I got a package deal.
I understand the sard ones will need a new fuel rail and maybe some sort of adapter for them to fit ??? Not sure tho.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
