RE30 18x10.5+18 white
Hi there -regretfully selling my set of RE30 wheels painted white
18x10.5+18 -perfect size for R33/34 gtr
rare wheels
Price dropped $2300 - pick up or shipped at buyers cost
won't last long , get in before you miss out
https://www.sau.com.au/forums/topic/470818-wheels-tyres/
  • 2 months later...
ADVAN GT 18x10.5+15 x4 wheels
Selling my advan GT wheels in satin black
18x10.5+15 wheels only
these are forged rims made by Yokohama and are extremely strong and light and clear big brakes
selling due to engine build
$2700 priced to sell
bill 0412351418
https://www.sau.com.au/forums/topic/470818-wheels-tyres/#findComment-7834107
HANKOOK Z221 semi slicks SOFT
Selling my hankook Z221 semi slicks SOFT
Feb 2017 build
295x30x18 (4) tyresused for 3 sessions at Wakefield
$1000
bill 0412351418
https://www.sau.com.au/forums/topic/470818-wheels-tyres/#findComment-7834667
On 23/06/2017 at 9:28 PM, Birds said:
What sort of tread they got left mate? 3 sessions at Wakefield could amount to anything really :P
They still have the HANKOOK visible in the rubber
https://www.sau.com.au/forums/topic/470818-wheels-tyres/#findComment-7837199
rare wheels
SOLD SOLD SOLD
RE 30 wheels are gone
https://www.sau.com.au/forums/topic/470818-wheels-tyres/#findComment-7840093
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
