  • 9 months later...
i ran a 10sec pass in my 2012 R35 GTR with just a midpipe, catback, and air filters. everything else was stock. 10.8 to be exact. i didn't even have a tune.
so with a tune and midpipe you should definitely do it, though if you were getting it tuned i would do aftermarket air filters, fuel pumps, injectors and downpipes as well at the same time since you are going to need a retune if you get any of those parts later on the quest for more power.
  • 2 years later...
My 2014 MY 2015 runs titanium midpipes. No idea what brand, but not a bad note. Have not had a tune as yet. Fitting Cobb catless downpipes, upgraded fuel pumps, ID1050x injectors and Big SF carbon intakes at the moment and will have a tune on completion. Not sure when as I managed to shear the turbo manifold stud on the left downpipe, the one at the 8 O'clock position. It was the last one so pretty pissed off, even more so when I broke a 3mm drill bit trying to drill it out. Off shopping tomorrow for a rescue bit and maybe one of those hollow diamond bits to drill around the HSS broken one. At least with this mexican beer flu around I have plenty of time to waste on cars.
Also agree with BLISTIC, hardly worth a tune for midpipes alone. Once you start down the dreaded upgrade path, watch out for the Kaching meter. Bought a set of pipes and then discovered there is no Accessport tune for that. Got to add the big intakes, fuel pumps and injectors which requires I think at least a stage 2 or maybe stage 3 tune to sync everything. Maybe next week if the world hasn't shut down.
  • 1 month later...
All done. Car has gone from a beast to a monster! Did a COBB stage three tune and the car is running so well I'm not bothering with a dyno. Only downside is having to drive with the windows down to savour the the brute note.
Literally saved around $3K on installation quoted costs, so more than enough to pay for the skin grafts to knuckles etc.
Having a hoist was a big advantage, although the trickiest part was installing the pod filters on the intake pipes. Actually resorted to KY!
The big beware is the downpipe nut removal. NISSAN use these bloody one use pinch nuts which can be problematic getting off. See above. It was at least relatively accessible. It could have been much worse and this engine has 14K on it. Not sure I would risk it with a high mileage one. Oh, and that sheared stud removal took me four days and a lot of swearing!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
