I removed my Hicas with an elimination kit, didn't cut any wires whatsoever and I haven't had any issues at all.
Did you remove anything besides the hicas rack? Did you cut any wires?
Try disconnecting the battery, leave it for 10 minutes and pump the brakes a few times to get any residual power out of the system. Connect the battery and try again
https://www.sau.com.au/forums/topic/470905-hicas-on-r33/#findComment-7835515
Only thing I removed apart from hicas is hicas fuse.. Did not cut any wires.. Thanks mate will give that a go.. Is the elimination kit you used the tomei one
https://www.sau.com.au/forums/topic/470905-hicas-on-r33/#findComment-7835517
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
