2009 Subaru WRX hatch
Hey all, I know this isnt a Skyline, just advertising here as I'm looking to free up some money to get into a skyline track car.
I’m the second owner from new.
2009 my10 so it has the high output widebody engine and turbo setup.
$15,990 on stock rims
$16,990 on the enkies
I've included a photo on stock wheels, no front lip, no roof racks and no plasti dip on the intercooler intake. Can be reverted to stock appearance in no time.
I'm happy to be upfront, there are a few very minor stone chips, as you'd expect from a daily driven vehicle.
I have endless paperwork from the owner’s manual, all services, parts etc.
Never been to the track, all mods have been done to make it the car it should have been from the factory.
197awkw
VF52 turbo
Heavy duty clutch
MRT XB upgrade kit installed
3” stainless steel exhaust with high flow cat
I've replaced the rear muffler with one that lets out a little more noise. So the car will also come with a 3" rear section that's a little more subdued.
MRT Tuned ECU
DBA 4000 series slotted rotors up front with performance pads, pads replaced recently.
Whiteline suspension bushes
Whiteline adjustable rear sway bar
Whiteline chassis brace
Whiteline diff bush kit
Whiteline diff mount kit
Whiteline anti lift kit
Whiteline tyre rod ends
Whiteline lower ball joints
Whiteline front adjustable swaybar
MRT sports springs
Short shifter
Front lip
professionally rolled rear guards
Enkie RS05RR 9.5” not a mark on the rims, yokahama rubber.
RAYS - Duralumin Lock & Nut Set - Red
Also have the stock rims with RW tyres that'll come with the car if you'd like them.
Tinted windows
Also comes with new Rhino roof racks
Will come with rego and rwc
122,XXX kms
serviced very recently, rego paid recently
I'm not after swaps.
Shoot me a message if you have any questions.
https://www.sau.com.au/forums/topic/470946-2009-subaru-wrx-hatch/
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
