Without afm??
Hi guys,after reading and trying to understand all this matter related to removing forever the stock AFM R33, Its not completely clear to me. I've at home about to tune an e-manage Ultimate greddy with sensor map. Could I definitively cancel the afm of my r33? Would be to connect in the ECU greddy in option1 the map sensor and this in turn with the pressure output to the butterfly manifold to perfectly read the amount of air sucked. Is this true? Or where the pressure tap would be connected? I'm very sorry for this great text,
Cheers mates.
https://www.sau.com.au/forums/topic/471066-without-afm/
Thanks mate, I'll connect it in the intake manifold, in one of the shots glued to the blow off I've an unused air intake. And with respect to remove afm and put this sensor map? In principle should run perfect? I'm very interested in your opinion. Regards
Just now, KiwiRS4T said:
sensor de MAP NECESITA Ser Conectado DESPUÉS del acelerador - es factible de, en algun lugar Fuera de la Cámara de Distribución ... Como Es el sensor del medidor de impulso.
https://www.sau.com.au/forums/topic/471066-without-afm/#findComment-7837671
I've seen that it also takes an Air temp sensor to completely cancel the AFM stock. Ive tried the way to create it in the ECU itself and can put an IAT sensor, in pins 30 and 36, we can put it to fool the ecu that we've tail still together with sensor map, and to be able to remove the afm forever. If u want the info the step without problem. Cheers..
https://www.sau.com.au/forums/topic/471066-without-afm/#findComment-7838177
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
