Big fuel pump choice with e85
Hi guys,
Basically I wanted to get some opinions about what fuel pump setup people are running for big power with e85, and namely what big single pumps people might be running. Basically 044 pumps, from what I have found, eventually sh1t the bed. Adding e85 additive helps, but only prolongs the inevitable I believe.
Basically had fuel pressure nose diving yesterday on the dyno, and I am fairly sure the 044's I have are not happy. One was actually seized at one point until it was tapped with a spanner, then came good again. I don't want to have to hit fuel pumps with spanners to get them going again, when they are feeding a motor with almost 20K into it.
I currently have 2x 044 feeding into a dash 10 line moving forward from boot/surge to engine bay, pumps would be almost 4 years old now I suppose.
I looked at the new Proflow FS11380, which is like an 044 alternative and seems to have a bit more flow (have to figure out the trickery again with @ XYZ bar, so might actually just flow the same as an 044 at 72psi), and again, on one website I read may decrease pump life if used with exotic fuels ie e85.
So I am looking a single 2345-A weldon pump:
http://www.weldonracing.com/store/2345-A-p56104058
Main reasons are:
1. Will modify reasonably OK into my existing surge setup, just need a dash 12 feed welded onto existing tank
2. Won't grenade the motor if I lose the pump, as oppose to losing 1 pump on a twin 044 setup
3. All race fuels compatible from what I read
4. Can be rebuilt
So before I shell out $1500+ to get this over from the states, what are other people doing in this space?
I'm keen to know.
Cheers.
https://www.sau.com.au/forums/topic/471321-big-fuel-pump-choice-with-e85/
What power are you doing with the walbros donut_kng?
Yep absolutely agree that fail safe can be setup for drop in pressure, which ill likely being doing with the link anyway regardless of which way I go. I have found totally conflicting info on some pumps. For eg, I looked up the proflow 044 alternate pump today, and one site said yep 100% e85 safe, the other was like, will decrease pump life by running e85.
To be honest I think there is some trickery with words getting around for e85 compatibility, if your pump can run e85 initially and it only last 6 months, does that still classify it as e85 compatible?. For me as far as I am concerned the 044 pumps are not e85 safe, despite what people may say about them.
How have the walbros been in that respect donut_kng? I know those are rated as e85 safe.
  • Like 1
  • 1 month later...
I'm making 525rwkw with this and it has been doing that since 2013, without ever opening the surge tank, I'm probably due to check the socks hanging off the pumps etc
Regardless it's fair to say the walbros do the job just fine as I have never had an issue with it.
I definitely recommend a fuel pressure gauge, as I did have an issue with the hat on the fuel tank which restricted the return line and made the pressure jump to over 100psi.. had I not had the gauge to spot it straight away I'd hate to know what would have happened eventually
I think people have issues using the wrong type of hose which breaks down internally
  • Like 1
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
