FS [SYD]: Splitfire Coilpacks w/ Box | Coilpack harness | Coilpack bracket & bolts
Hey Girls and Guys!
So you may know or probably not know - I bought a NEO motor. This means majority of my R33 RB25DET stuff is pretty much useless on this motor.
I have a wonderful load of items for sale for such a lucky person! No more misfires, no more coloured coilpacks that aren't blue dropping out and causing ECU outputs to short circuit or ECUs to shut down. These are the real deal, no bullshit Splitfire SF-DIS-005 Coilpacks!
You're thinking, this guy actually kept the original box? yeah I sure did! I always wanted to sell them and convert to Yaris coilpacks one day, but that "one day" turned out to be 4 years! Anyhow, enough random bullshit this is the break down:
  • $300 - Splitfire Coilpacks with the original packaging
  • $50 - OEM Nissan quality coilpack harness, no cracked clips!
  • $50 OEM Nissan quality coilpack harness for RB25DET motors (long live the VCT!)
Because I am Asian, there will always be a best pry cash deal. I do speshcal pry, $350 you tek de lot - kesh only.
Price: $350 the lot
Fitment: ECR33 S1.5/2 (no ignitor pack) and BNR34
I will only post if you direct deposit - no PayPal because there are too many dodgy scammers out there. Pick up > Post.
5 hours ago, john boost said:
Hey mate would you sell the coil pack harness seperate?
Sure will!
OEM coil pack harness no longer for sale. Turns out the R34 NEO and R33 will work however the plug lengths are incorrect as the coil orientation is different. Schematically the harnesses are identical.
Now for sale is my Wiring Specialties R33 RB25DET S2 coil pack harness. This is about 1.5 - 2 years old or so.
$100
I said you could borrow it before lolol..
I thought I could use them on the NEO head but it doesn't fit :(
Coils are sold
Coil brackets are sold
Still left, Wiring Specialties Coil pack harness.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
