R33 GTR Front Diff Bearings
Does anybody know the cross reference part number for the R32/R33 GTR front diff bearings? I've stripped it apart and brought the bearings to a bearing shop to no avail. Was suggested it has to be OEM.
Otherwise, if any shop is willing to sell me the complete set of;
Diff centre bearings x2
Input pinion bearings x2
Input pinion seal x1
Bearing retainer seal (driver side front shaft seal) x1
Shoot me a PM and price with delivery to Perth metro.
https://www.sau.com.au/forums/topic/471610-r33-gtr-front-diff-bearings/
Part numbers if it helps:
bearing pinion - 38120-03V00
 bearing pinion - 38140-03V00
 BRG taper...... - 38440-03V01 x 2
 BRS-side shaft.- 38440-03V10
 seal oil..............- 38342-03V01
 seal oil............. - 38342-03V11
 ring o retainer...- 38343-03V01
 seal-oil drive.... - C8189-03V00
  • Like 1
  • 3 years later...
Yes it is as i used it for mine.
Be aware that when rebuilding you may need new shims to reset the pinion preload and also the crown to pinion mesh. some of these shims are discontinued and make it hard to get the correct tolerance.
Dont just slap the new bearings in as you will have issues at a later date.
