2002 Nissan Stagea Axis For Sale
Selling my 2002 Stagea Axis. I have purchased a new car so no longer require the Stag. I have had this car for the last 5yrs and it has been a terrific daily. Pretty stock as it was my daily.
It is a 2.5lt v6 turbo,12xxxxkms.
Nismo catback exhaust
Alloy radiator
slotted rotors
Offset caster rod bushes
super pro adjustable sway bars f+r
Both front windows tinted to match the factory rear tint
Pivot cruise control/throttle controller
sony double din dvd player
New Falken tyres purchased this year.
I replaced both cam sensors last year other then that have not had a problem with it
The condition of the car is excellent,no dents! but the rear fibreglass/plastic? apron has fading and cracks, I have attached a photo, rest of the paint is fine.
Mechanically the engine and transmission are A1 zero issues. there is occasionally a slight knock from the front right suspension, I believe this to be the std link rod from the swaybar. I have 2 new link rods that I will give to the new owner.
Other then that there is only two issues
the seat switches are stuffed
and the tailgate struts need re gassing
rego runs out 28th august.
Plates not included.
Factoring these things in I am willing to sell this car for what I consider an absolute bargain.
$6000 as I'm looking for a no nonsense quick sale.
Car is located camden/campbelltown area.
I am a shift worker so if you could please reply here or sms. Daniel 0419200851
Cheers.
https://www.sau.com.au/forums/topic/471688-2002-nissan-stagea-axis-for-sale/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
