R34GT-Four Vibrating and clicking
Im in the process of buying a R34GT-Four coupe. I inspected the car and seems like the car vibrates almost like the drive shafts have been blown. So I looked at the the tyres on the vehicle and he has different wheel widths. Now im in the process of finding out how much this will all cost to fix the issue.I have a few questions Does anyone have any experience with this on their cars.
I was going to drop in a RB25 AWD turbo engine. But im worried that the AUTO engine may have a different RC ratio. I checked, RC = 4.3 and found out from the Forums that RC 43 means it was auto. It has been changed to a manual.
I need some direction on what to look out for and if it will be possible to drop in a turbo engine (Auto) with RC 43
https://www.sau.com.au/forums/topic/471689-r34gt-four-vibrating-and-clicking/
If front and rear rolling radius is not the same the transfer case could be stuffed. Or it just has stuffed cv joints. Any turbo AWD you get will have a 4.1 diff which means you have to change the c/w and pinion in the sump or the diff at the back to match.
  • Like 2
I thought R34 GT Fours had the 4.3 final drive?
4.1111 R34 RB25DET manual/auto
4.083 R34 RB25DE auto
4.363 R34 RB25DE manual
Wheel widths shouldnt make a difference but i would be worried if the profile is taller/smaller as said above.
  • Like 1
That's great this is the information I'm hunting out for. Trying to get as much information as it is a risky purchase.
I understand that, if the RC at the front is 4.1 the rear will have to match this too. Is there anything else that I need to do so it works smoothly? Currently the car has RC 4.3
I'm getting JEM to have a thorough look at it to see the extent of the damage.
I'm quite handy with my hands so I could do the rest myself provided I know what's wrong with it.
Alternatively you could take the front diff you have now and transplant it into the turbo casing. But if you leave the front and put a 4.1 into the rear you could look for a proper mechanical LSD
I'm buying a turbo neo engine. I think it would be better to use the diff that comes with the turbo engine (4.1). Just from a quick search seems like the 4.1 ratio is more popular. Not sure if there any disadvantages with going to a 4.11 ratio.
So correct me if I am wrong, 4.1 at the front and 4.1 at the back. Would I need to change anything inside the box/transfer case?
Update, car came back from one of the "reputable" garages in Sydney. They reckon the steering rack is what is causing the car to vibrate while driving. I was trying to think how the ticking is in any way or form related to the steering rack. Maybe some one can educate me on GT-Fours.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
