Hks turbo Identification
Hi guys.
i have a used hks turbo in my possession.
Chra tag states it's a 3076r chra
tag # 700177-5007S
i have not seen a 3037 with this front cover, only a 2835 pro. anyone else have this Comp cover on their 3037?
Rear housing is a .7 t3 hks dump pattern.
any help greatly appreciated
https://www.sau.com.au/forums/topic/472066-hks-turbo-identification/
That will almost certainly be a HKS GT3037 Pro S , assuming it hasn't been interfered with . They look virtually the same as a GT"2835" Pro S except the turbine and compressor are larger in diameter . GT3037 is HKS speak for what Garrett calls a GT3076R in 56 compressor trim . Pro S is for their unique compressor and turbine housings .
The turbine exducer or outlet diameter should be around 55mm .
Cheers A .
Cheers A .
Thanks for the response disco. Was hoping you would chime in.
This turbo capable of 350ish rwkw with a .82 rear, on a neo with 85 on board, all in ?
HKS did GT Pro S turbine housings in 0.68 and 0.87 AR sizes . I'm not sure if the 0.68 AR one would get 350 RWKW especially on PULP .
In theory you should be able to use a Garrett T3 flanged IW turbine housing on that unit and most opt for the 0.82 AR size on RB25 turbo engines . Those Pro S turbine housings were gold in the days before Garrett were making integral waste gate housings of their own - which are same format as the Ford XR6T T3 IW turbine housings .
A .
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
