Ecr33 Work wheel MD disk front fitment
Does anyone have experience fitting a work MD disk wheel face with oem ecr33 calipers? I'm not sure if I will need a spacer to clear the caliper and I want to make sure I order the proper offset if I'm going to have to kick the wheel out a bit.
8 hours ago, Leroy Peterson said:
What model wheels is it for? spoke design is a bigger influence on caliper clearance than disk choice.
My guess, mid disk will be heaps of space for OEM R33 calipers.
Thanks for the reply Leroy! The wheel faces are Work VS-SS
Im currently running 18x9.5+20 all around and like that look so wheels are same specs, only thing changing is the rear at 10.5in
Thanks for your input! Cant wait to get the wheels next week!!
18 hours ago, Leroy Peterson said:
So 18x10.5 +20 doesn't clear the rear brakes? Is that what you're saying?
Not sure where you're getting this conclusion form previous posts. All subjects and statements made are about the front caliper clearance.
you said you were running the same specs, but only changed the rear?
or have you gone from a 1pc wheel to 3pc in the same specs? any photos?
Only thing changing on my new wheel setup was the rear is a little wider but thats not a issue. My main concern and reason i started the topic was for the front caliper clearance with the Work Md disk.
Yes,  I was going to a 3 peice wheel setup with the same specs in the front but I know some disk type dont clear big calipers. Shop I got them from estimated a 5 to 8 mm spacer but I wanted to check if someone had done it before so I knew exactly the spec of the spacer i needed.
Ecr33 + work MD disk = need 15mm spacer in front
Case closed :cool:
