Raced the car over the weekend, put the advan a050 on & got a wheel alignment friday.
Did some logging on the way out to the track and was having weired issues with it hitting a MAP Limit randomly under load.
Round 1 kept hitting a limiter at different loads and then lost all positve manifold pressure. Checked all the intercooler pipes and nothing wrong so pulled all the pipes and checked to see if BOV was stuck open but it was fine. Ended up pulling the external gate, stripping & inspecting it. Found nothing wrong so assembled it all started up and went for a quick drive and had boost again. To be safe I zeroed the wastegate table above 3500rpm and did the next session and no issues so random.
Car was perfect after that and ended up going 47.45 Finished 1st in class and tied 4th outright was beaten by rcr skeleton, BMW M3 race car, 400kw WRX and 600hp LS ae86.
The adavns are still the best tyre I have used and won't be going back to the nankang. Throttle blip was good for 2 corners and added another 5%. Need to do an oil change & bolt check will be sorted for another event. Should also look at a new clutch as was slipping towards the end of the day.
Really want to put the fixed back seat in so I'm not sliding around......
  • Like 5
1 hour ago, ActionDan said:
What are the Advans worth? what size you running?
I am still planning on moving to used slicks like the others in my club.
$2400 255/40/17
Every event I generally go to slicks would put me in open/formula classes. Would like to have a go one day with some. What slick are you going to go?
Ouch, 2-3 times the cost of AR1s?
In my club my car will already be the top class after the engine swap so i might as well run the same slicks they do (porsche cup i think?)
I will toss up what Semi's I use for other events. The Hankooks look OK.
Keen to see how much life you get out of those Advans. What compound?
So far done v8 sprint last year (5x 20min), around 1000km Street driving and this sprint day. Most people I know who run them get at least a year of sprint racing and consistent to the end.
Medium compound
@Dose Pipe Sutututu will do. Got to get a new alternator as drops voltage in hot weather and when all the fans and lights are on.
  • 1 month later...
Took the sil80 out to the local hill climb for a run sunday. Car decided it didn't want to make boost so just ran it like that and still managed a 1.04:52 and 6th outright. Had a chat with some people about about the issue and seems the wastegate is getting stuck open so pulled it apart and found a few areas were marked on the valve shaft so cleaned it and linished the the shaft put it back on and everything seems fine now.
Booked King of QR in September and will start getting it ready for e85 and retune in the next few weeks.
  • 5 weeks later...
So after cleaning up the wastegate went back to the dyno with a tank of ethanol and did a bit of constant load tuning and got the fuel table good, went to do a power run and only made 4psi of manifold pressure. checked hose and did another pull to 4000rpm to see if happened again. Cracked the shits loaded it up and straight back in the shed. Gave it a day and investigated a bit more....................
Found the issue causing no boost........ Catalytic converter had collapsed after I had pulled the turbo off Batman Facepalm GIF by WE tv
So cat is now high flowed.
Decided to put rego back on it as got over towing it 7km to the dyno so now have a tank full of e85 and dyno booked for the morning. Been driving it daily for 2 days with no issues so far so will see how much the setup will make then do a few runs at lower boost levels to have a variety of Wastegate DC tables I can use.
  • Like 1
Do you think Vicroads will let me re-reg my car after it has a full cage????
I've rarely heard of a cat actually collapsing and never personally seen one.
What causes it? Heat? Age? Abuse?
Probably not but should enquire about rally rego, that's what we have here.
Too much heat, vibration probably never looked at the why.
So it survived the dyno with someone who has a lot of experience and knowledge. That's all just on gate spring and solenoid just keeping it closed until 3500.
received_845041613045365.thumb.jpeg.cbc04a261a32672709b1555fc133cb18.jpegreceived_2634885473482331.thumb.jpeg.80709f55ced0016307d1dc29adab324d.jpeg
Any more boost and would blow spark out. Going to leave it for now and look at upgrading coil packs, alternator and clutch in the future.
  • 1 month later...
After the dyno pulled the plugs and swapped back to usual NGK and no more spark issues car went awesome.
Did Targa Great Barrier Reef as navigator again in the commodore and took out Classic GT Class. Car is so much faster now with new engine and gearbox setup.
240496310_4563997920277709_7566054420528933515_n.thumb.jpg.0c4e2c61b730fcb3c08e82993d3bb129.jpg240876773_4563997943611040_1463038011123165673_n.thumb.jpg.99b83ccc4524750c7230804f70e69134.jpg
Done a few events in the past few weeks, ended up driving to the sil80 all the way to Brisbane and back all on e85 around 3000km. Did a test day at Lakeside DTC with Skid Control car was solid all day with no issues then did King of QR had a few issues with manifold to turbo nuts coming off & loose and pumping the catch can with oil. Fixed it all and did all but one layout, besides those problems car was super quick and all on the nexen sur4g (200 treadwear) which was pretty good for a budget tyre. Lost the starter motor for the last session and had to be pushed to started to get out on track and back to the brother in laws 😅
IMG_20210915_145645.thumb.jpg.b42626979fbba120c1afdc2b656154f8.jpgIMG_20210916_103349.thumb.jpg.d928655d7fc4c50aa11ccfe733b55c54.jpg
IMG_20210918_063015.thumb.jpg.6604a3afd72ada12d8e191ee18b2d0e6.jpgIMG_20210918_113257.thumb.jpg.8e77e2c3280356f2074d14f270022c98.jpgIMG_20210920_122756.thumb.jpg.b1744cbe80ae638d15ca18394224f529.jpg
242248481_10159308679958950_3546059362623945890_n.thumb.jpg.769128c381b9a05deb30fea64b3d8dc5.jpg242321425_10159308679633950_75565321251240667_n.thumb.jpg.a5f3e40339294e67f231654c08b1d76f.jpg
Got back home and did a lot of maintenance with all fluids and filters changed. When draining the gearbox oil had a lot of material and a synchro clip come out so box will be out soon.
Did the local hill climb and smashed my PB with a 59:43 which got me 4th outright and fastest rwd, got beaten by all the EVO's and a WRX.
Been daily driving it and still pretty cool to cruise around in and am finding it more comfortable than the 370.
Got the last sprint for the year next week, wanting to hopefully better my PB and maybe take the class win for the year.
  6928EF36-5E0B-461D-9221-F82643582732.thumb.jpeg.9c0b98be93cd103c0063a374413df9f9.jpeg613581F9-BE55-4169-9884-E4717DBE12CD.thumb.jpeg.8635443aab9c17c2495a89686fa40ca4.jpeg
  • Like 3
On 10/1/2021 at 8:11 AM, ActionDan said:
Hot damn son what an update, Out there killing it :D
Box plans?
Going to rebuild it with fresh bearings, synchros and 3/4 selector upgrade. Hopefully gears are still good.
  • 5 months later...
Don't think a hoist will fit in here 😅
All moved down to Ipswich now. Got first hot hatch cup round at lakeside Saturday. Had a few problems with the getz running and it's stuck in Rockhampton at the moment so will be using a mates car.
Also got 2nd place in class for last season sprints in Townsville and only doing 4 of 7 rounds which is cool.
Edited by robbo_rb180
On 3/17/2022 at 11:50 AM, ActionDan said:
Maybe a quick jack or a 1.2m scissor hoist etc. Can be moved around too.
Nah it's coming down.
7x9x4 3 bay is going in, just waiting on detailed quote. Going to put in a clear floor hoist 😁
How's your build going, been much more progress than what you put instagram?
  • 1 month later...
Had the sil80 out a few weeks ago for some 1/8th mile drags at Lakeside. Car is hard to launch and just spins but once gets traction in 3rd is a jet.
Clutch was not engaging properly after 2-3 back to back runs and gearbox wasn't very smooth either. Been filming heaps lately and putting on YouTube.
Shed deposit is paid and should start early July
  • Like 1
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
