Just wondering about purpose/control of the little coloured squares appearing under people's avatars.
They are green, black, red or in my case not coloured at all. I also noticed that some people have have a couple of red ones.
Whats the G-O with these?
Ta,
Ben
https://www.sau.com.au/forums/topic/47246-little-coloured-squares/
Its like little coloured squares.....
BTW nice letter in current speed mag PranK
Well, yes i guess they are like little squares arn't they... :D
Thanks dude, what a little turd that guy was.
:( funny letter..
not sure about the square thing.. really just opens off to slagging in a more mature manner, or buddies just bumping up their mates.
its weird i have reputation points for months ago before the reputation thing was even created i think! what is up with that?
p.s. prank you're shameless, you should be ashamed of yourself :D
i did like the "xxx is disabled" part, was it intentional??
lol
:D funny letter..
p.s. prank you're shameless, you should be ashamed of yourself ;)
lol
Bah! You can only hope to improve! :(
