ok so i have done alot of reading on this but im still a little inclear as some say yes and some say no, anyways my aircon hose was melted when i had a screamer pipe on it that was pressing up against it, i dont have the screamer pipe on it anymore and i fitted a replacement hose, so obviously i have no gas in the system at all anymore. I want to get it refilled but im unclear what type of gas to get it filled with, some say its r12 gas that it takes and that they dont use that gas anymore and that i am supposed to have the fittings changed to r134a fittings and that i am supposed to have the compressor modified to take the new type of gas, but then others are saying that it was a scam and that r134a can go straight in it without any modification to the compressor and that i just need to get an adaptor for the fill fitting. At the moment it has the stock pale green cap on the fitting. So my questions are:
what gas is supposed to be in it, is it r12?
do they still sell the r12?
is r134a safe to use in it if it was made for r12?
does the r134a rot or seep through r12 seals?
do i have to have the compressor converted from r12 to r134a?
if it was your car what would you do to it?
thanks guys
https://www.sau.com.au/forums/topic/472508-r33-aircon-gas/
R12 is dead....died with global warming.
R134A is the 'environmentally friendly' alternative, it is not as good cars that were made for R12, but on some later model ones you would be lucky to see a difference.
I haven't heard of 134 affecting seals etc....and yes some fittings have to be changed for 134.
if it was my car I'd take it to an A/C guy [or several businesses] and talk it over with them, his replies and knowledge will help you decide who knows their stuff and who you will trust.
https://www.sau.com.au/forums/topic/472508-r33-aircon-gas/#findComment-7856384
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
