I got afew quality parts left as i have sold my r33
Rsr invidia stainless 3inch catback for r33 gtst
Good hiflow exhaust thats very quiet but does not have the 2.5 inch restrictors like most jap exhaust with the jasma plate robbing you of power
$250 ono
Rare moon face dump and fr pipe stainless steel to suit r32/r33 5inch oval shape
Good for lowered cars as it sit up nice and close to the body
Has a nice unique not and discontinued item retail $799 vgc
$300
R34 op6 turbo good cond no shaft play comes with lines and outlet and actuator
$250
Custom metal intake made by dvsjez to suit standard airbox off r34gtt which should fit r33
$120
15mm gktech spacers 5x114.3 with wheel nuts $80 pair
Stock r33/r34 gtst pink label afm working cond
$50
Whiteline 22mm solid rear swaybar with bushes for r33
$80
Genuine bride brix 1.5 drivers seat with genuine rails freshly retrimed and rebolstered for r32/33/34
$450ono
Enkei rp01 white 17x9 +22 gtr offset wheels 5x114.3 all round lil curb rash on the edges
Plenty of tread
80% fr dulop direzza 225/45/17
60% rear bridgestone 235/45/17
$1100 ono
Jap stern racing 3 piece gold wheel
17x8 fr 17x9 rear staggered plenty of tread
+30ish offset plenty of tread
Bridgestone turanza fr 60% 225/45/17
Nankang rear 265/35/17 50%
$450
R33 5stud1507286412933.jpeg1507286465914.jpegIMG20170826201201.jpeg rear hubs and wheel bearings good cond
$100 pair
R33 gtst s2 mspec grill paonted white
$150
All parts located syd outer west
https://www.sau.com.au/forums/topic/472579-r33-aftermarket-parts-wheels/
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
