Hey everyone,
So 2 of the rims that came on my car when i brought it have now cracked in the same spot, so figured i may as well buy all new wheels. i've spent a couple hours last night searching the wheels and offset thread, found alot of good information but couldn't find enough to get a proper answer.
I am looking at getting some Rota P1R wheels. having some trouble making sure i've got the right offsets tho.
The choices are the following
18x9.5 +27
18x9.5 +35
18x9.5 +38
Have compared my current to the the following on WillTheyFit.com, but still not sure which would be the best choice, i think the +27 on the front would stick out to much but not sure if the +35 would be to close on the inner.  But i think the +27 would fit the rear pretty nice, Going to jack the car up this afternoon and try and check clearance.
Just wondering if anyone knows off the top of their heads the best offsets to get?
Cheers in advance.
Hey mate.
They're basically perfect, as I have 9.5 and +27 all round. You WILL need to roll/lip the guards if you want to run chunky tyres. I run 265's all round and I do not get scrub and I mean that will barely fit.
The 9.5 +38/+35 will hit at the front. Need a spacer.
IMO, the +27 at the rear pokes more than the front does, I was suprised that when putting same wheel size on all 4 the fronts natrually are a little more in.
I want a 10+38 on the rear so I can run a 285/295 for max tyre.
So ultimately, you may need a spacer or two if you go for the +35/38 combination, the 27 will max it out. 35 with some spacers/extended studs will get it to sit in a little.
Awesome, exactly what i was looking for, i was a bit worried about the front inside hitting the suspension arms but seems it will be okay :)
i will be running 245/40/18 on the front and 265/35/18 on the rear.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
