Selling my 1990 R32 gts-t 4dr.
Location Riverland SA
$5,500
Imported to Oz Oct 2003 and has been my daily driver since then.
317xxx km's
Motor replaced at 255xxx km's supplied by Rollin Automotive Imports. At that time all hoses and gaskets were replaced new coil packs fitted. Cooling-Pro alloy radiator fitted with new thermostat, Blitz turnflow FMIC fitted and oil cooler fitted.
Only other modification is HKS catback exhaust.
Front seats and rear seat base have been replaced with coupe seats in two tone grey. Rear back-rest is still the standard sedan item as i needed to modify the bottom bolt bracket on the coupe backrest as it was too short and I never got around to it. Full sedan interior still available if you're a purist. Genuine Nissan floor mats (drivers one is quite worn)
2 new tyres, 2 less than 6 months old. New rotors and pads (rear) Front shocks less than 12 months old. All rear hicas ball joints and rack ends replaced in the last 18 months. Front rack ends in the last 2 years.
Front upper control arm bushes need replacing.
PM or text 0447633539
20171116_110837.thumb.jpg.9e899a7c1112175625528bddf4683a4f.jpg20171116_110909.thumb.jpg.3c43025be7a4ea14893abad14597d774.jpg
20171116_110850.thumb.jpg.cea94759170857bcfc235d7ba5ae0e4a.jpg20171116_110921.thumb.jpg.0f7e41282334c3eab12f4fb1726bd7d0.jpg
20171116_110932.thumb.jpg.62d3791c9ff10eabcf4d6c066af28e11.jpg20171116_110942.thumb.jpg.47beb9080dad1b7d1623ce8c4cf753e7.jpg
20171116_111048.thumb.jpg.c63c0187a68644565c819702567d94af.jpg20171116_111009.thumb.jpg.bbec888182cb3a20c0a257bdcca82bc6.jpg
Spoiler
https://www.sau.com.au/forums/topic/472689-fs-r32-gts-t-4dr-manual/
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
