MR R33: i still have the stock springs, i guess they'd be like most other springs that u can cut down and make lower...
cheers...ben.
hi is there any possible way of getting the springs to sydney.i live near paramatta and if you are near the area would you be able to drop them buy.can i have your mobile number so i can contact you because im interested in the springs very much
MR R33: i might be coming to sydney soon... do u need them urgently? if u dont need them urgently when i come up we can meet up...if not i can send them to u...
cheers...ben.
yes that will be good.i am doin a whole car rebuild bodywork,rims,suspension,interior,engine so when you are coming to syd let me know plz cause its not urgrnt but 4 sure i will take them.just P.M me a few days before you come up.
thanks
  • 5 weeks later...
  • 2 months later...
hey mate, nah sorry i dont have the antenna no more,
im goin overseas and will be back on the 14th of jan, so if anyone has any parts i can still use email but wont be able to organise any selling till i get back,
i also have
- 2 12" subs in a box, which came with a little car i just bought- $250ono
- checkerplate floor set for front and rear floors (real metal not rubber) -$50
there will be alot of other parts as soon as i get back...
cheers...ben.
  • 8 months later...
* stock r33 gts-t front pipe and dump pipe with heatshield- $10ono
Is this the heatshield for the turbo? If so, can you ship to the Northern Beaches of Sydney?
Cheers!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
