R32 RB20 cross over pipe, BOV $50
2x GTR BOVs $30ea
IMG_20170429_133743_zpsupmy8nuc.jpg&key=a0b631ca52b57045489c46cd11d5247f0fd0ea7a53488e43ed35cf28a647f813
6x Intercooler Clamps (HD) $20
IMG_20170429_133817_zps9hqtvgkb.jpg&key=7bbe10eee3d0f5e0c5a1da035d3d0e4f732a996c3de5969cf37201d31b421945
RB20/26 Cam Gears $10
IMG_20170429_133827_zpsc9cvqcdj.jpg&key=62ae72bb357cc4776a8524468b1d3cc53e1a4e70e483a5d22f5cbd8d1c44031d
Walbro Fuel Pump pickup extension (E85 Safe) $40 - only test fitted
IMG_20170429_133749_zpsilgn4oib.jpg&key=2fdde576114ddf5b928d06e3516a075886aa7ff2aa83be8716180cfd047724bc
52mm coilover sleeve x2 & gland nuts x4 $50
IMG_20170429_133727_zpsg9uxzkvl.jpg&key=300ffff41cac4f64ec9822c3f39dff29993cba9502cae43adf7d61cc545107c4
R32 standard RB20 intake plenum (upper & lower) w/bracket for R31 $50
IMG_20170429_133700_zps4suclk0d.jpg&key=20fe5eb27d01ae120efac036bcd2e536941c118cd5a8b7efdd1c3a34df1fd40a
R32 RB20 water pipe (new) $100
R32 rb20 Front facing plenum.
Machined flat in a jig to ensure that it's straight.
Includes PFI fuel rail, throttle cable.
Can throw in new water pipe.
$500
R33 crossover pipe W/standard bov $50
With GTR bov $70
R33 gtst intake, injectors and rail $100
R33 gtst loom $100
R33 gtst auto ECU $50
R33 gtst S1 hotside.
Turbo, manifold, oil and water lines.
Awesome rb20 upgrade.
$300
R33 rb25 ignightor and coil pack loom $100
R33 rb25 oil filter heater hoses and oil filter housing $50
Located Western Suburbs of Melbourne.
Pickup or can post at buyers expense.
https://www.sau.com.au/forums/topic/472925-shed-clean-out-rb20-25-30-parts/
  • 4 weeks later...
Ill take this guy if you still have it, tried to pm but said you couldnt receive it.
Can you post to nsw 2566, thanks Russell
Sure.
Not sure about the PM thing.
Will try to send you an PM with payment deets.
Postage will probably be between 10-20.
Will get a quote.
R33 turbo, fuel rail and injectors sold.
R33 GTST intake with all sensors, now $50
Have R33 GTST rack ends available $40pr
Rb20det front facing plenum & fuel rail dropped to $400
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
