Think they are the same they will fit yes but I used s14 ones.....depending on your cars other suspension ie: adjustable or stock it may cause problems. either way you'll need a wheel alignment when you put them in
They are 10 - 15mm longer than standard r32 gtst hence, without any other adjustment and all other things remaining equal, you'll be running more camber and your castor rods may not be long enough
Edited by bcozican
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
