3 hours ago, G3TFKD said:
Yeh sorry mate. I've been getting smashed left, right and centre with a new baby and work.
I'm out for this one. Too much going on at the moment and my car is not ready to go.
My mates are indicating like they are dropping out as well.
Hahah!! No worries man!! Congrats on the little one though!
On 5/14/2018 at 9:07 PM, sammi_d said:
FFS, Looks like I've blown my motor on the weekend, whats the chances of pulling out if I cant get it fixed on time ???
  • Sad 1
You serious Theo!?!!? Damn!!
Refund policy is in the description. Short story is:
- No refunds, unless the day is full and there is a waiting list; but,
- You can swap your spot out with anyone else, so long as you let us know who you've sold your spot to
Let me know whats happening at your end...
  • Thanks 1
1 minute ago, Dave76 said:
Are there positions vacant still I’m think just have to drive the car tomorrow to make sure the cars all good but if it is are there spare vacancies
Yes, there are places still available!
Let us know if you're 100% on entering... @wagon boy may be looking to sell his spot...??
yeah I'm 100% out :( the motor has blown the rear rotor.
Rhys was going to buy my spot but haven't heard back from him yet.
  • Sad 1
1 hour ago, ianjb said:
What? We need to go full hommo with tow straps and stickers? but i tease people that put them on their street cars.
That is because they only go to Mcdonalds, not because they go the GPcircuit.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
