https://www.facebook.com/events/144367356234846/
== SUCC MOTORSPORT DRIFT CAMP 2018 ==
=> The Run Down <=
March 24/25 (Camping from the 23rd)
2 Days of Drifting, Tandems, Passengers, Competitions
Coaches, 100% Beginner Friendly
Camping included in the event cost
Meals included in the event cost
=> Pricing <=
The event is $239 for both days, camping and food costs
$50 discount for those who have paid for UTAC 2018
=> Event Specifics <=
Wilby Motorsport Park
Awesome track out near Yarawonga, see attached videos for details!
=> SUPP REGS <=
Edited by Pr0x1mity
  • Like 1
I hope so! We want to try run more events like this one (We hold the track license for Wilby) in the future! Its cheap as f**k, don't have to worry about acom or dinner sat night etc and we're not compromising by having 80 spots. Limited spots available!
Hopefully we get some SAU guys on board so I'm not the only Skyline there (Doubt I will beeeee!)
If you have any questions shoot me a PM or ask in here!
At the moment on the event page we're looking at running a few little fun comps for the sunday.
Here's a video from the track :)
Still limited spots left, once thats done we'll take a waiting list.
-Cheap!
-2 days of drifting + CAMPING AND FOOD INC!
-CAPPED ENTRIES @ 40
-Max track time
-No bullshit
-Beginner to pro friendly
-YTB
-Get on it
  • 1 month later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
