The ECUTEK has RACEROM, the rev match is enabled (I am really bad at heel toe) this does it for you.
Also has flat foot shifting enabled ( ECUTEK uses both fuel cut and ignition retard working together), if it was just fuel cut I wouldnt use it, I like my pistons, if it was just ignition I wouldn't use it as I like my turbo.
It has launch control, but this feature has never been enabled.
I may be interested in a mint original AUD S15 with cash my way.
Minor mods are good but......
Disclaimer: No pi gs, no respays, no 400hp fully dayglow spec with body kits, no prior accident repairs.
I will have it checked out with a fine tooth comb.
I have been looking around lately at S15's, I want a good one though, and by good I mean mint, the better the car the less cash my way.
Example: I missed out one 2 years ago, it had 4k original km on it and it sold for 28k.
Both cars will end up at a local shop for inspection, Pulse Racing is close to me.
  • 3 weeks later...
On 5/14/2018 at 2:25 PM, The Panda said:
If you are looking for a p-plater fun weekend car - I have an AP1 S2000... 4.44 diff and some other fun stuff. I need a more work appropriate car :(
Shoot me a email with some more info and pics mate. How much do you think the S2000 is worth realistically.
Thanks for the email
Your car looks sweet but sadly not what I am after.
I wish you luck with your sale.
Cheers
  • 4 weeks later...
Keen to hear your thoughts on the 86, coming from the STI, by the looks you got the limited ed. ver with the brembos, sachs and updated diff?
Really liking these at the moment, just finding it hard to find $30K from the back of the sofa.
So far so good, I replaced the Michelins with some RS4's today, should be good once they are scrubbed in, I had some RS3's on my MX5 and liked them alot.
In the couple of days I've had it I'm loving it, even with the crappy Michelins it was a hoot, it's good to be back in a light(ish) RWD platform.
Power wise it wouldn't pull the skin of custard, but that not the point of it, or why I got it.
Wringing its neck, throwing it into a corner, playing with some oversteer is so much fun.
I also grabbed a cat back for it, a XForce 2.5" jobbie, sounds alot better, well you can hear it now anyway, with the stock cat back I couldn't even hear the exhaust, I estimate the power increase from the cat back is an astonishing 0%.
So, for future mods, some alignment bolts from whiteline are on the cards, stock camber adjustments are non existent, apart from toe, stock camber is 0.0 deg, I'm going to hammer some corners and see what the tyres are saying and dial some in from there.
Cheers
  • Like 1
On 7/3/2018 at 9:31 AM, JGTC said:
Awesome, good to hear Mark, i totally agree with you on that simple layout is best as i get older, more fun at less speed with less to go wrong.
Camber bolts only gave me -0.5 with them maxed out, rears are -1.3 L and 0.97 R (not adjustable).
I'll try some 14mm lower camber bolts for the front and see where that puts it, if all else fails I will grab some strut tops as well, I will grab some adjustable arms for the rear.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
