Someones having a worse day then me. :P Rule of thumb figures are:
- $1500 for a manifold,
- $3000 for a turbo
- $800 wastegate
- $800 injectors
- $2500 ECU installed and tuned
- $1500 intercooler installed
- $1500 exhaust installed
- $1500 clutch and flywheel
Then youll have a car with plenty of power but lacks the niceties such as:
- $1200 cams installed
- $2500 suspension
- $500 brake pads and fluid
It aint cheap.... for more detail then the above, then thee SEARCH button is our friend.
Thats rough figures, for new bits at retail...shop around you can get cheaper new/2nd hand and different brands
  • Replies 86
thanx heaps ROY....
ohh i aint saying i got a high performance car...im saying i want 2 build my car into 1...read properly an stop just jumping on ppl..
I see you've got no comeback about not being able to write English properly :cheers:
yeah well i know how 2 drive decent enough...an all i want 2 do is get the right turbo setup from the strat so i dont just have 2 get another 1 later....i aint going to run it 2 its full potential just yet either so dont worry.....
all i wanted to know is how much a minifold would be nd roy answered that 2 me...does anyone know anywere that sells manifolds 2 suit an external wastegate setup..i kant find any... thanx anyone who can tell me
Its cool to dream. :)
Mods take time and lots of money.
As soon as he realises how much he is really up for he may be happy with just 200rwkw or so..
As soon as you start hitting 250rwkw you have to be prepared should a motor to let go. There's another 6.5K.
Before you know it you've spent as much on the car as what its worth.
Do it in stages..
Exhaust, FMIC, bigger fuel pump, ECU then look at the suspension turbo manifold and injectors.
Go for a ride in benms car before you start thinking about needing a bigger turbo straight up. A well sorted std turbo R33 can be made to boogie :)
Like Joel said, its nota bad idea to get the basics out of the way (in order) like exhaust, filter, intercooler, cam gears, ECU, clutch...then by the time you are ready for a turbo you will have all the support systems with the exception of fuel pump and injectors which are dependent on how big you go.
I wouldnt call it dreaming, its planning ahead...i wish i had followed a more logical path to modifying my car...woudl have saved a lot of money and probably have twice the power...but its wise to have an idea of what it al costs before you start.
i have a 3" turbo back exaust, hks pod filter with cai, boost controller, tein ajustable supension.....an i will admit damn i was strugling 2 get traction already b4 i blew the turbo up...but since i have 2 replace i want 2 replace it with sumthing that has lots of potentioal..long long long term i want 300kw.....thats it..if i wanted more i would do a RB26 transplant instead..
ohh yeah ill tell be honest..i got offered a 500Hp garrett turbo that need an external wastegate for $400 brand spanking new neva been used an still in the box.. just want 2 see if i kan afford 2 do the whole setup properly...thats y i just need 2 know but modding the manifold or gettin a second hand stainless steel one 2 suit...
To get 300rwkw you will need an engine build with forged pistons.
Anything over 350rwkw and you will need a set of forged rods.
Simply doing an RB26 transplant isn't really worthwhile.
You are better off spending the $$ on a good set of forged rods.
Not many people go down this road as it is serious $$.
sorry joel possted at the same time as you...yeah i dont want 2 go over 300kw....would be 2 much for me...and i will only be running it under safe limits..like 250kw max untill i get more $$ to get forgies..
Even with 250rwkw be prepared to shell out for a rebuild should the thing pop.
If you want it to be reliable you will need to drop the compression ratio with a thicker head gasket, fuel pump, injectors, exhaust, fmic and an ecu.
Then on top of that all the labour to fit the headgasket, injectors and tuning of the ecu.
This will blow out to a lot more than you realise.
How much are you planning to spend honestly.
How much do you think you can afford?
not alot..as u kan c im only 17 an work part time when im not at skool....got ony bout $1600 to spend to get this turbo prob fixed at the moment...not much at all
What mods are already done?
So your std turbo is stuffed?
I would scour the forums for a cheap second hand RB25 turbo.
Spend $150 or so for a dyno run to check the af's.
If it is leaning out spend the rest on a decent fuel pump.
If you have already got the fuel pump sorted, spend the $$ on a PowerFC then save up for a little to get it tuned. Tuning is generally around $400-$600.
That will give you a big power increase depending on mods. :rofl:
joel thanx 4 your help mate...i just really wanted 2 get a good turbo this time...i only had the last 1 on 10psi an it kicked the bucket...but i will take your advise as that is what i posted this thread 4..to get advice
like i said b4 i have a 3" turbo back exaust, boost controler (turbosmart in cabin 1), really good HKS pod filter in a cold air intake box...
so you think just replace my turbo with another stock 1 ay....an my car is running really rich at the moment (fair bit of rich fuel smoke when i get up it)
brand new 500hp turbo for $400??
What truck did it fall off?
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
