  • Replies 49
how about 10.8seconds down your street, and screaming all the way to the formal. will cost you a bit for fuel and other expences like rub and tug on the way home after we drop you off at the formal.
nah like ill pay sum $$$ for the drive...but the actual place the formal is held at from my house is like 100m away.....mad..... so i was thinkin like ill pay abit of money if u could take just me for a quick cruise around... and den come back and pick up my date and drive up to the formal place...???
Nah keep your money.
Skyline owners obviously have some dosh.
But line up all the year 12 girls ya got and I'm sure all the SAU members will be there to help your group.
T.
Guest two.06l
i hope you have checked that alex is free that evening.im sure he would enjoy the attention on the way home.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
