Hi gents,
Came back from a two week holiday and did a service on my R33 s2 Rb25det.
Changed Oil, cleaned afm with electrical cleaner and swapped back from pod to air box and snorkel with trust filter. I run a air box 99% of the time.
I was giving it a boot at night on Monday and noticed it wasn't as quick as it normally would be with less of a punch in the mid-range. Basically felt like it would on a hot summers day, rather than 10pm at night heading into winter.
As it's SAFC tuned I can see the AFM reading as a percentage and normally in summer it would hit 76-80% and in winter 82-87%
It was hitting low 80's this night but just felt slow.
Started fault finding, re-cleaned afm, checked fault codes, Checked for loose hoses etc
No obvious boost leak, still hitting and holding 10psi and turbo is not any less responsive than usual. Removed air box filter lid/filter/snorkel for a run and only marginally quicker but didn't seem like it was the issue.
Replaced the fuel filter too, no difference.
I then removed all corrections on the safc so it was essentially just running stock and I couldn't tell the difference.
Kept doing runs with 0 corrections and then adding the corrections it was tuned for and I can't tell the difference.
So now I'm at a bit of a loss, I don't have a wideband to see if the corrections are effecting open loop AFRs  or if the fuel pump is dying. Had a walbro put in at the time of tune 5 years ago.
Basically it's had the same setup, 10psi, MBC, return flow and full exhaust with SAFC tune for 5 years and all of a sudden it just feels like it's slower like it's lost its tune/less ignition timing.
Any ideas, whether could be fuel pump dying, still a marginal boost leak or a problem with the SAFC?
Just want to try anything before getting it on the Dyno.
Cheers
Patrick
I would suggest getting a wideband gauge if yr using an safc. I think my aem one was under 300? Have had it a few years on car and still going strong. Otherwise yr shooting in the dark adjusting safc, and in the danger zone. .not the good Kenny Loggins type either
Thanks for your response.
Yeah this is basically the next step.tried
First measured voltage at VCT plug. Requires 2ppl, as car must be in gear.
Voltage was there, so removed vct and made sure it would actuate(audible click) and visually see the Piston move using the battery. It didn't the first go but then after re-applying 12volts it did.
So cleaned it up, re installed with plug on and made sure I could here it audibly click/engaged.
Ideally I could have done that from the beginning but nevertheless it solved my issue.
  • Like 1
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
