  • Genuine HKS-used, in good condition
  • Adjustable Vernier Cam Gears / Pulleys / Sprockets
  • Complete Set of 2 Pulleys
  • Maximise your Engines Performance
  • Tailor Power Characteristics and Delivery
  • Alter the Power Band to be Higher or Lower
  • Plus or Minus 20 Degrees of Adjustment
  • Lightweight Duralumin Centre for Increased Response
  • Quality 12.9 Grade Steel Fasteners
  • Price $200 including postage with Australia
https://www.sau.com.au/forums/topic/473974-parts/
Genuine HKS Timing belt kit, brand new still in bag. Comes with tensioner & idler.A full timing belt kit for the RB26DETT engine. Part number 24999-AN001
Please check that this belt is suitable for your vehicle: https://www.hks-power.co.jp/en/product/engine/timing_belt/application_chart.html
Price $180 including postage with Australia.
https://www.sau.com.au/forums/topic/473974-parts/#findComment-7875018
Yokohama Advan A048 235/45/17 tyres x 4. Used as track tyres.
Yokohama tires are designed to perform better, keep you safer and take you further. The ADVAN A048 is a street legal tire-created for short-track racing. It features technology inspired by world-class racing tires to provide better grip and faster lap times. The ADVAN A048 easily transitions from straight-line sprints to high-speed cornering, enabling predictable handling. And its race-ready compound always delivers durable track day performance.
Price $120. Pick preferred but can arrange courier
https://www.sau.com.au/forums/topic/473974-parts/#findComment-7875021
 Rebuilt R33 GTR Turbos (Will also fit R32 and R34)
These have upgraded 360 degree thrust bearings and Steel / N1 Spec Exhaust Turbines
Fully rebuilt and balanced back to new tolerances using high quality components.
 A great upgrade over stock ceramic wheel
turbos with excellent response & good for 300 + kw
No oil or water lines to modify - straight bolt on replacement. Never fitted to my GTR.
Price $950. Can post if required.
https://www.sau.com.au/forums/topic/473974-parts/#findComment-7875084
Fuel upgrade for your GTR. Includes Bosch 680 cc injectors x 6 (Bosch 0280150845 pink top), aftermarket fuel rail & generic fuel pressure regulator. Suit RB26, excellent upgrade package
All parts brand new, never fitted. Price: $450. Can post anywhere in Australia.
https://www.sau.com.au/forums/topic/473974-parts/#findComment-7875087
Set of four alloy wheels 17 x 8 front & 17 x 9 rear with Dunlop SP Super Sport Race tyres 245/40/17. These tyres are a street legal semi offer amazing grip. Wheels made in Japan in great condition with no damage or gutter rash. 5 stud pattern 5x114.3 PCD. (offset 35 &40 respectively F&R). Were on a R33 GTR but will fit most Skylines and other makes.
Price $ 500. Can post at additional cost.
https://www.sau.com.au/forums/topic/473974-parts/#findComment-7875121
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
